Ignition and light switch for early super 88
I have a 1955 green wheeled Super 88. Right now it has a key ignition switch with push button to start, and push pull light switch. Should this tractor have a combination ignition/light switch like the fleetlines, or is what is there correct? Thanks,
Josh
Is the key ignition switch correct? The key doesn't match the newer Oliver keys, but it's not a lawn and garden style replacement either.
Josh
I am pretty sure that is correct. I have 1 gas & 2 LP green wheel super 88's. All 3 tractors have a simple on/off key switch under the dash behind the hydraulic unit & the push button starter switch. According to the parts book, gas super 88's serial # 6503-49249 used the on/off key switch, gas & diesel super 88's used the push/pull light switch, & serial # 120001-49248 used the push button starter switch. I did find the combination switch used on magneto ignition tractors.
