Mike(NEOhio)
- Location
- Newbury, Ohio
I could not get the lift arms to drop consistently. They would work a few cycles then stay up. The free travel is in spec and the bypass valve is closed. I was pushing the control lever all the way forward to lower but I found that the arms drop consistently when it is about an inch back from there. Question 1: Is this normal operation or is there something else to adjust? Question 2: My plowing experience was on trail plows. With a mounted or semi-mount plow, is the depth controlled by setting the stop on the control lever?
