My neighbor has a 2-105 tractor that had leaking O-rings on the throttle shaft. He was to my place a few weeks ago while I was doing a similar repair on our 2-105 except for my shut down seals were leaking. He decides to tear into it himself today and does not pay attention to what holes the governor spring was hooked to on either end. I was able to determine it was in the middle hole on the control shaft but can not figure out what hole for sure the little pin that the spring hooks to was in. I was hoping maybe one of you guys might know or am at trial and error until the rpm responds correctly. I really do not want to take my housing cover off again to see where mine is hooked. It is a CAV model DPA pump. thanks
