Pto cluch fix
I have never seen a video. But the repair manual is easy to follow. If you have a shop or garage to work in it makes it a lot easier to split the tractor, which you will have to do. You will need some jack stands or something to stabilize the one half while you use a floor jack or hoist to move the other half. About the only special tool is one to release the clutch retainer nut. You can make one out of pipe. I have included a link to a Super 55 split which would be similar to a 550, someone with a 550 can correct me on this.
Super 55 split
