oliver OC3 water pump
Hello, I have the Hercules IXB engine and need to replace the water pump bearing and seal.
I have the water pump out. Wondering how to get the pump apart? Is it pressed together???
Yes, the shaft is pressed in. Zimmerman's has a rebuild kit with instructions. I did mine a couple of years back. Also used a special lubricant for seals. Don't remember if it was included in the kit.
Hello, I got the entire water pump pressed apart! went pretty easy. I plan on putting it back together by the end of the weekend. thanks
