Need front engine cover for Oliver 99
In search of a front engine cover for Oliver 99 302 engine and the metal ring that goes between cover and engine block. Thanks.
It's sounds like your taking about the rear engine cover, the plate that the starter bolts into? If you are taking about the front engine cover it will be different based on fuel type.
This is the one that has the hydraulic pump drive in the cover? There was a 190 Waukesha near here that had one of those covers. It was on a blacktop paver. I wanted to buy the engine but he did not want to sell it. I heard later he scrapped it! So maybe start looking for some other applications that used a Waukesha 190/195 engine.
No hydraulic pump drive, i think a 88 is the same. Mainly just need the metal plate that goes behind it. The block on a 88 is shaped to the cover. The 302 in a 99 is not.
