1755 water pump
I needed a new water pump on the 1755 and had a hard time removing the pulley from the old pump, so thought I would be smart and lube the shaft when I pressed the pulley on the new water pump. Not so smart, pulley came loose and the fan blades into the radiator. Question, what now, will the pulley stay if I clean it up and press on dry? Thanks
A press fit is a press fit. Any oil or grease will wipe off if it's a proper fit. If it's a little loose, you can use Loc-tite bearing retainer (green), but it sounds like either the pulley is bored to big or the shaft is too small. Only way to know is start measuring.
Donovan from Wisconsin
If a pulley goes on too easy, I always weld the pulley and bearing shaft.
Just dig in enough with rod so it holds. Never had a problem and only had one come off in almost 50 years(no weld).
If you ever have to pull pulley, grind off the little welds.
