Was going to put my 1600 on the 3 bottom today to go some plowing along with the 1855 and 4 bottom plow, but the 16 didn't want to lift the plow. Dad moved the plow this summer film one shot to another and it worked fine then, but now it won't lift just the arms unless you bring the engine up around 1500 rpms. I did have to mess with the restrictor valves a little while doing loader work this weekend, but with them adjusted back to where they were before hand I still got nothing.
Bad cylinder seals? Or should I look somewhere else first... might be a while until I can take a look at it.
We ended up putting the Massey 285 on the small plow and we still had 7 bottoms in the ground today so we weren't at a stand still, but the 285 just doesn't do it as good as the 16. I plowed until I had to go to work, and then dad took over for me and we had a family friend on the 18 until it broke a tie rod.
Donovan from Wisconsin
