Been chasing an air leak in the fuel lines and filters for a couple days, seem every time I thought I had it, it still
would not start come morning. Could still get her running by bleeding injectors for bit and then she'd run for the
short time I needed her or maybe catch air while running longer or when I was working to find leak. Well this morning
no chance of her firing bleed the injectors or not. That's when I noticed a leak around the throttle control lever on
the injector pump, wasn't there before I don't think. First question could a leak there cause the problem of engine not
starting? Second if the problem is deeper than that inside the pump should I attempt the repair myself or take it to a
shop. I'm kinda thinking it is the pump now and sorta figured so before but was hoping it wasn't.
