Oliver 1600 rebuild
buzzbait
New User
Without knowing exactly what i am doing i am rebuilding the engine. All apart now just need to put it back together. I need to know all the torque specs and any bolt pattern. Going slow and leaning as i go.[/b]
(quoted from post at 14:50:39 10/17/15) Without knowing exactly what i am doing i am rebuilding the engine. All apart now just need to put it back together. I need to know all the torque specs and any bolt pattern. Going slow and leaning as i go.[/b]
This is a gas tractor. I have spent good money on two manuals but neither have the spec I need. Any help will be great.
Here you go! Been there and done that but you should find a I&T manual and a mechanic to check your progress. Doing it right is not a low budget process I have a $500.00 reground crank waiting for my 1650 rebuild. Greg
(quoted from post at 03:21:24 10/18/15) Here you go! Been there and done that but you should find a I&T manual and a mechanic to check your progress. Doing it right is not a low budget process I have a $500.00 reground crank waiting for my 1650 rebuild. Greg
Thanks for the help. Will put it to good use. I do have someone to train and help me.
Mr.Schwiebert knows all about Olivers but if you need something else just give a holler! I am lucky to have a neighbor that is an excellent mechanic and jack of all trades but is a dairy farmer so he is busy all the time. My dad was a mechanic in the Air Force for 20 years but he is long gone and I was young and more interested in chasing girls.
