I just purchased a Super 88 with I believe a later model engine. I expect to need some parts, but would like to know what to expect before tearing tractor apart. The only numbers I can find are behind carb cast on block. 155119A, 190620, 1292
Can not find numbers supposed to be by right rear eng mount. Pictures of oil filter in front of dist, later style dist, later style dipstick, cause me to think it's a 1600 or newer engine ? Engine cranks fine, pistons move, nothing in valve train moves. Have you ever seen this problem ? Are they prone to broken camshaft ? Don't see how timing gear could come off or lose key ? Some of you pullers might of seen this problem. Thanks for any help.
