550 Gas tank
LeakyBoot
My sump keeps rusting pin holes in it. It is leaking down around the ignition and I'm looking for a big fire soon. Where can I get a new tank? Or is this not possible? LB
Remove tank, power wash, use hydracloric acid diluted to rinse tank, rinse out with water again,dry tank, use a good tank sealer and let dry.
(quoted from post at 18:48:52 09/29/15) My sump keeps rusting pin holes in it. It is leaking down around the ignition and I'm looking for a big fire soon. Where can I get a new tank? Or is this not possible? LB
Check EBay, I just searched and found a tank on there for sale.
Any rad shop can reseal your tank with a coating inside it. Downfall though they hot tank your tank and strips all the paint and impurities from it in this process. Duane o.
