Casey Gildersleeve
I recently purchased a older grain drill and had pretty high hopes it would sew seed again. its an oliver 76. #88603-bx.
Im looking for the gears that mesh together when the drill is lowered to drive the common shaft for the seeder cups. All the cups are good and ive fixed everything else when i found the broken teeth on both gears (the fixed gear and the sliding gear). Any leads would be greatly appreiciated.
Casey
Casey
