Power steering on 77
I have a 77 with char lynn power steering added. The motor sticks out past the curtains (never with the tractor since I've had it. I'd like to restore and add side curtains. Do any of you have a power steering setup like this that works with the side curtains? I have a super 88 without power steering that I thought I could swap the setup too since the side curtains are open. Any thoughts?
Josh
I have charlynn units on both a 77 and and 88, the curtain will close but you can not use the rear latch as there is not enough room for it between the power steering motor and the tub. I just leave it unlatched and let the front latch do the holding. One could also use a bolt if you wanted a tighter fit.
