Farmall Guy Found an Old Oliver - Need some Help
RTR
I realize I was talking alot. Just wanted to clarify that I'm looking for the correct size bolts for the front rims, or if they are studs, or what-have-you. Not sure what I need and what is correct.
If there is an online Parts lookup for Oliver that you guys could tell me about that would be awesome! I doubt there is though.
The parts I am looking for are to fit a 1948 Oliver 60 Standard (wide front) and is believed to be an Industrial Model.
Looks like I edited my post rather than replying to it. I apologize for any confusion.
Thanks.
(quoted from post at 20:25:43 09/05/15) I realize I was talking alot. Just wanted to clarify that I'm looking for the correct size bolts for the front rims, or if they are studs, or what-have-you. Not sure what I need and what is correct.
Hi RTR
I have a 1948 Oliver Industrial . What is the serial # ? You can get some parts from Steiners in Mich. If you have any other questions email me. I will have to look at the bolt size when I go to my storage unit. Will write later.
Here is a picture of the Tractor and of the Serial Number Plate. Am I correct in saying it is a 1948 Oliver 60 Standard Industrial? I
actually found it about 4 years ago and haven't done anything with it yet. She has been sitting on her hubs since with new tires in the
building already mounted. I'm wanting to get her off the ground so I can start working on it to fix up.
Just checking to see if anyone might know what I need. Would like to get her off the ground and start the restore.
Thanks.
(quoted from post at 16:00:47 09/22/15) Go to the link below. Select Guess User. Select White and enter 60. Select Oliver 60 and view away.
http://www.agcopartsbooks.com/PartsBooksN/login.aspx?region=NorthAmerica
Their parts book system does not give any details of the part except for the part number. It is virtually useless for finding the bolt size. Going to call a dealer to see if they can help. I hate to have to order "regular" bolts from them. The Case/IH parts site gives sizes and details of parts where this one only gives a part number.
looks like regular bevel headed fine thread cap screw. You should be able to get them at NAPA Tractor Supply or any tire store that deals in Agri Tires.
