1550 oil in radiator
. It has a separate oil cooler mounted in front of the radiator. Guess I will have to pull the head and check gasket and head for crack, tractor has been sitting for a couple years.
Are there 1 or 2 coolers ahead of the radiator? If there is one it is a hydraulic oil cooler. You have a serial number for that tractor? You have a phone number?
I would be looking for water in the oil.
Think here pressures. There is no high pressure oil supply at the top end to force oil into the cooling system - more likely the other way round. I would suspect core plugs in the
head are leaking and there will be water in the oil after some running.
I think theres only 1 cooler in front of the radiator. I know theres 2 lines on each side going back too the hydra power. I will look tonight for serial num. 270-849-7252 call after 6:00 pm eastern thanks
(quoted from post at 17:44:57 09/21/15) Are there 1 or 2 coolers ahead of the radiator? If there is one it is a hydraulic oil cooler. You have a serial number for that tractor? You have a phone number?
there is 2 small coolers in front of the radiator. The serial number is 216 367-502 model is 455-52012
