Zenith Carb ID
Kerwin
My "new to me" 1850 gas has a Zenith carb. Is there anywhere on carb that would give model number? I'd like to get a rebuild kit. Carb tag is stamped "0808" and "015107" if that helps. Thanks.
You might call "Zenith Fuel Systems", 14570 Industrial Park Road, Bristol, Virginia 24202, Phone 1 276 645 8619/8662. Tell them what you have and what you need. I've gotten two new carbs with their help.
The kit for a 15107 carb is # K2137. In stock at the Zenith distributor I deal with in Toledo. Lists at $28.51 + S&H. Your tractor was originally equipped with a Marvel-Schebler USX series carburetor. Per Zenith the 15107 was a JD replacement.
