Oliver plow size
farmerwithmutt
I remember seeing that some oliver plows you can take the front bottom off and make a 4 bottom into a 3 by sliding the hitch over. How close is the front beam to the rear tractor wheel ? Also what size can the be made into are they just 16 and 14 ? I remember the bolt pattern on a oliver plow I had and that was easy to switch .
Thanks Larry
The 565 4 bottom could be converted to a 3 bottom. Later on they made a 3 bottom 565. We sold a couple of those behind 1550 tractors
That's what I want to put it on . Friend bought 2 plows then decide he only needed one so someday I've got to go get it just wondering if that setup will work thanks . The price was right otherwise I would just get a 3 bottom .
Thanks
