Re: oliver 60 wiring
J. Schwiebert
It should only gave a cut out not a regulator. I can look and see if I still have one. If I do I will need your snail mail address to send it to you.
J. Schwiebert, my email is todd.d.day at gmail dot com. If you send me an email, I will gladly provide you with my snail mail address. I can't get the private message to work on this forum.
Thanks for the reply!
Big thanks to J. Schwiebert for going the extra mile to help me out with my Oliver 60 wiring! Took the generator apart, cleaned the commutator, reassembled, and wired it to the regulator as per his instructions. Battery is charging as indicated by the ammeter. Thanks again, J. Schwiebert; you're a true gentleman.
