Oliver 1450 Lug Bolt Size
I am sure you looked in your parts book. I looked in one other book and I see the front wheel bolts are 20 MM X 1.5. If you take one of those out will it fit in the rear wheel hub?
Thanks, the front lugs are the same diameter as the rear lugs only the fronts are shorter.
This one 1450 has adapters on the rear that adapts the wheels down from the large center
1450 pattern on the hubs to the smaller size centers like the 1365 but to complicate
things the lugs on the adapter that uses the 1365 size wheel center has slightly larger lugs.
