White 2-135
I have a white 2-135 that I am having problems with the hydraulics on it. It will raise an implement by the implement shakes on the way down and sometimes will not go all the way down. Is there a check valve somewhere that needs adjusted/replaced or what might my problem be? Any help is appreciated!!!
   You need to adjust the lowering restrictor on the remote valve.   [b:654c4848f0]To adjust:[/b:654c4848f0] Stand behind the tractor & you will see the remote valves.   Notice an adjustment screw on the under side of the valve, It's a screw with a blade screw drive slot and locked into place with a nut that take s a 9/16" wrench.   Loosen the nut on the valve you are using and screw the screw all the way in and back off about one turn.   You will probably find it backed all the way out.
   Attach the implement that you are having the concern with.  Start the tractor and run long enough to warm the hydraulic fluid, now adjust the engine RPM to where you are running it when making most of the movement of the cylinder.   Hoses must be hooked up so that the cylinder is extended when the lever is moved back and retracted when the lever is moved forward.   Now make your final adjustment to where the cylinder travels at your desired speed while moving smoothly.
