Gear ratio on 1950 fwa
rrman61
Do all1950 fwa models have the same ratio for the front /rear axles.I have two not running and need to use one as a parts tractor.They are set up the same with 14.9-24/23.1-34's.will post serial numbers later if needed.might have to mix and match front and rear ends
Question is;how to determine what ratio each of my tractor front differentials are?is there a tag or stamped no.somewhere?i want to know what I've got so I can interchange axles if I have to.I will post the serial numbers tommorow
   Post all the information that is on your serial number tag both model and all nine digits in the serial number. I believe there were six front axle differential ratios.   The original ratio was stamped on the top of the front differential housing, however how do you know someone has not installed a different differential in the housing?
