Have some oil leaks?
ol 55'
Tractor runs good but a couple of transmission leaks, not quite sure how to go about fixing them. 1st one at the brake pedal shaft. 2nd one at the cross shaft that picks up the 3 point bothe sides, and last but not leased there is gear oil coming out of the lower access plate with 4 bolts holding it on just below the PTO unit. Looks like I have a leaker here, any help would be very thankful. I believe I have to break the super 55' in half to work the access plate just below the PTO? :?
Thanks there super 55', hey where can I order a manual like the one you where showing me? Mine is a new one not as illustrated as yours. Thank you..
