PTO clutch discs
156 086A. Number replaced the older K part number when the 1600 tractors were introduced. If you want the older number I need to look it up, this one I still had in my head. J.
I just redid the clutch in my 1555, uses same discs. The aftermarket discs are thicker than the OEM parts you will need extra shims. The parts may be available from this site. If not they are available from your nearest A&I Products dealer.
