550 oliver 1960
Bison2010
I put a new cluster in and temp. gauge does not work. the gauge is grounded , there is power, I took the wire off the sender and momentary touched the ground and nothing, its suppose to be neg. ground, could it be pos. how can I tell. I tried 3 different sending units none of them worked. any ideas what I could try. I have an alt. in it that's why its neg. thanks
Did you buy a new negative ground cluster gauge then? Because the original in a 1960 would have been positive.
