white electric speedometer
gdb
I have an electric speedometer to put in my 2-155. Not the acratach, but the speedometer that goes on the left side of the dash in place of the speed chart plate. The pickup that goes on the front bevel pinion bearing retainer is bad. Any ideas on where to find a replacement? It is a Stewart-Warner 990e magnetic pickup. Help and advice appreciated. gary
Thank you, MKuhns. Would you tell me more about the piece you used? Where did you get it and what is it called or a part number. gary
It is just a magnetic pick up (speed sensor) for the speedometer when mounted at the rear of the trans or even a tachometer when mounted in the flywheel housing. Anyone that handles truck parts should have one. May have to splice the ends together. I got a used one from work over 10 years ago.
