Super Powers
I only use my 570 Super for pulling so I've removed the entire PTO in order to get into a lower weight class.A PTO is not required in the division I'll be pulling in so I'll make a plate to bolt to the rear in it's place.
Do I need to also remove the power shaft coming back from the trans with the splined female coupler or can it just stay in place.My fear is that it turns all the time and may not stay put.
If it does need to be pulled out,is it that simple or is there more to it then meets the eye.
Thought I'd better ask someone who knows rather then making a costly mistake.
