I have an Oliver 1750 Diesel and I was replacing a leaky fuel return line boot and after i got the boot replaced i started the tractor and where the fuel had run down the side engine it was making air bubbles from between the head and block. So I shut it off the engine cleanes all the fuel off the engine restarted it let it warm up good the took some soapy water in a spray bottle and squirted a little on the seem between the block and head and sure enough i got bubbles between 5 and 6 cylinder on the exhaust side. It doesn't get coolant in the oil and tried pressure testing the radiator and it holds 7lbs for 30 minutes... Could it be just a bad spot in the gasket? I have an IT mannual are the torque specs for the 9/16 head bolts 1-6 at 150 ft lbs and7-14 at 133 ft lbs. Are these correct?
