2-70 PTO Seal
'67 1550
The bearing on the PTO output shaft went and so did the seal, its now leaking pretty bad. From what I gather by looking at the manual, it looks like the entire housing has to come off to get at the seal. For those of you that have done this job before, is there anything else I should replace for preventive maintenance or at least check while I have the housing off? Also, it seems like a homemade spanner is required for getting the nut out? Thanks
