Engine/3 speed swap
robertm
Hi everyone. Just curious. Will the engine and 3 speed from a 2-105 bolt into the tub on an 1850? Robert M
While I believe the engine is the same, and the over/under is, I think the White's used the same tub as the 55 series Olivers, which, if I understand correctly, is different than the 50 series.
However, we have a '65 1850 with a Perkins from a mid-70s MF combine in it, so I'm not sure the mounts are any different on the engine itself.
(quoted from post at 19:41:33 08/02/15) Hi everyone. Just curious. Will the engine and 3 speed from a 2-105 bolt into the tub on an 1850? Robert M
think the tail of the 105 3 speed is different(no sprockets and chain)
It's been a long time but I think the 1850 front mount is on the timing cover instead of on the sides of the block like a 105.
