Polarize 6 volt Positive Ground 77
60 Fan
I know it has been asked before but now needing to replace voltage regulator on 6 Volt Positive Ground '50 Model 77. And, I am not sure, make that forgotten how polarizing was done. Thanks in advance for assistance.
   Since the Negative post on the battery and the "B" terminal on the regulator is common only a short wire is needed to momentarily make contact between "B" and "A" terminals.
