Hello, went and looked at an Oliver backhoe yesterday. Good, solid tractor, but needed a little TLC.
The boom rotator is hydraulic motor, probably 12" in dia, and 15" high. The boom drifts really bad when idle. Assuming rotate motor is bad, are new seals available?
Power Steering appears to be out, are pumps and motors repairable and available?
The F/R worked pretty well, but sometime it wouldn't return to N, have to idle way down to shift gears sometime. Is this normal?
Thanks for any help, I know this is a rare bird and probably not much info about it. Thinking about calling Korves Mon morning for any advice, is there someone else more knowledgable?
