Oliver 1600
LDCJerryMN
New User
I have a Oliver 1600 and noticed there's many filters on this tractor.... I am aware the normal filters on the motor and air filter.
But this tractor has several filters on the hydraulic system and rear axle and hydra- power drive,
Question I have......how often it needs to replace and can I do these filters replace at home ? any requires to bleeding after I replace the filters ?
This tractor has 9500 hours on the dash.
You should be able to do all the filters. Look for a manual online or spend the big buck and order an owner's manual through your AGCO dealer. It will explain the fluids and filters plus help adjusting the clutch among other things.
