1650 with baler/ wagon
codyw
i have a 1650 gas with a newly rebuilt engine. we will soon be getting a square baler with a thrower and some wagons. will this tractor run the baler and pull a loaded of hay alright? some of our fields have some moderate inclines to them, which was my biggest concern. just looking for some insight before i get ahead of myself. thanks
(quoted from post at 19:07:39 07/21/15) i have a 1650 gas with a newly rebuilt engine. we will soon be getting a square baler with a thrower and some wagons. will this tractor run the baler and pull a loaded of hay alright? some of our fields have some moderate inclines to them, which was my biggest concern. just looking for some insight before i get ahead of myself. thanks
There are serveral veriables here to say that it will be able to handle it just fine. You need to consider how much does your 1650 weight, how big of a baler, how big are your wagons, and how heavy are your bales?
I have never been on a 1650, but I baled hay for 15 years with my Oliver 1950, JD336 baler, and 18' wagons. There were alot of hills that I would be cutting into while going up and there were alot of hills that I needed the extra weight (tractor) to hold me back. We had to use common sense when loading wagons. I would of perffered to bale with the JD 4020 becuase it had a diff lock and better controls, but the 4020 was much nicer to run the roads with the wagons.
What I am saying is that you will probably be ok, but use common sense when you have a load behind you. Just because someone says it will handle it, don't believe it. Be Cautious until you have a good feel for what your working with and working against.
The more you can rake your windrows on the contour, the easier it is to pull a baler and easier to change wagons. It helps if your brakes are in good condition too.
Pay attention to Haymaker! He is talking common sense. Any person using a 77 with a baler and wagon does so a his own peril unless it is on level land and the load is small. It sounds nice to say follow the contours but one always risks a wagon overturning if it has much of a load. Going up or down a hill has it's own set of risks. You might not have enough traction to pull the hill (it is not an easy thing to back a baler with a wagon attached). It can also be exciting to go down a hill and only have marginal control. All of this being said, your 1650 should do fine with moderate loads and good brakes as long as the tires are good and the ground isn't too steep.
Do you think they always made tractors as big as a 1650? Before we had the 77,Dad always baled with the 66 pulling a baler with somebody stacking bales on the wagon. This is the whole "I need a 5 plow tractor to farm 40 acres" thing all over again.
(quoted from post at 21:50:35 07/21/15) Do you think they always made tractors as big as a 1650? Before we had the 77,Dad always baled with the 66 pulling a baler with somebody stacking bales on the wagon. This is the whole "I need a 5 plow tractor to farm 40 acres" thing all over again.
The problem is not that they need a bigger tractor to do the same job as they did in the past; it’s the fact that people ask these questions on this site on a regular basis. When I hear “will my will my 1650 do this or will my 1850 do that”, I hear a novice asking a question and looking for advice. The vast majority of the time I will read a response to their question such as, “you will be fine with that setup” or “you will be walking the dog with the that setup”
Without stating all of the variables, how do we know that they will be fine with it, or it will walk the dog???? Just because someone had no issue at all with that set up, it doesn’t mean that the next guy will have the same successes. This can be very miss leading to the user and can even jeopardize their livelihood.
I’m for sure if I asked “will my 1950 handle an 8’x18’ dump box full of shell corn”, I will get some responses on how great the 1950 will do with the load and not even know it’s behind me; but in reality not knowing all of the variables can kill someone. If I was on the flats with no mud and did not have to worry about making a quick stop, then I would probably be OK. Would I want to go down a hill with it [u:0f06b1e680][i:0f06b1e680][b:0f06b1e680]NOT KNOWN [/b:0f06b1e680][/i:0f06b1e680][/u:0f06b1e680]that there is around 30,000 pounds pushing against me? Probably not unless I was complementing suicide.
What I am getting at without known and stating the variables we can miss guide a novice. Just because an old 77 or 66 worked in the past doesn’t mean that it will work for me or the next guy. In the end; the user should use a lot of common sense in understanding the situation
You should be fine. Just keep in mind how you're going to want to bale it when you mow it.
If you have steep ground, you want to be able to start your load on the steep parts, then have some level ground to finish up the load.
You also have to think about how heavy your baler is - even if the tractor can hold back the weight, a loaded hay wagon will push your baler, especially in turns.
As with doing anything new, take small bites and chew them well, until you get used to it.
Pete
DO NOT GO DOWN HILL IN UNDERDRIVE
You don't say 2 speed or 3 speed, however both will run away with you in under, keep them in direct or over drive.
Nothing like trying to load hay on a wagon going down hill when the driver is in low trying to hold back with the brakes. Also need the rear tires loaded for traction.
Yup, that is defiantly one of the most important variable involved with baling hay on a hill with them Ollies. I did not want to bring it up with all these die hard Ollie guys!!!!
I realize I am a bit late with my thoughts, but I would say check around your neighborhood and see what is being used in your area. if a similar size unit works for others you should be OK.
I pull the same setup, less thrower, here in SW MO. Used to be around the same in SC PA years ago, but neither area is as steeply hilly as perhaps SW WI or the Appalachians.
30,000 thousand lbs,behind a farm tractor,that would be dangerous. The tractor better weigh the same as the load.
With good brakes, if you can limit the weight of the baler and wagon to no more than twice the weight of the tractor you should be OK on 15 percent slopes. What size wagons will you be pulling and how many bales will be in a load? Is a moderate slope 5 percent, 10 percent or 20 percent grade? Are there weights or fluid on the rear tractor tires?
(quoted from post at 05:44:12 07/22/15)
It is certainly a good thing he is getting advice from an expert like yourself. Wow just think you may have saved his life! And the common sense thing ... brilliant!
Your oh so right...too many times on this site you get the generic answer on how great that old ollie is and you won't even know that the load is behind you. I am glad that I am starting to hear users chim in with more of the different veriables, not just the standard "you will be fine with that setup!". I do admire the die hard Ollie guys and there passion, but more awarness needs to be presented when soemone ask can my old Ollie do this or will my old Ollie do that....
Far from an expert...
Common sense anit too common, if it was they would not be asking can my Ollie do this or can my Ollie do that???
How ever common sense is stating the veriables, not just providing a false sense of security and saying your Ollie is the best thing in the world and you will have no problem with that set up.
I apologize. I never should have given advice without this disclaimer. I hope you're still alive to read this Cody. I could never forgive myself if anything happened to you as a result of my carelessness.
1.Actual crash results may vary
3.Adults only.
5.All federal, state and local income and other taxes are solely the responsibility of the winner.
6.All major credit cards accepted.
17.All materials copyrighted.
18.All models are over 18 years of age.
20.All research statistics are blatantly flagrant.
21.All rights reserved.
22.All sales final.
23.Allow 4 to 6 weeks for delivery.
24.Alternate toy available for children under 3.
25.Always drive on roads, not on people.
27.Always wear your seatbelt.
28.A.M. stands for morning.
29.American Animal Humane Society: Safe for use around pets.
31.An equal opportunity employer.
32.Any other application constitutes fraud.
33.Any reproduction, retransmission or rebroadcast without the expressed, written consent of Major League Baseball is strictly prohibited.
34.Any resemblance to actual persons, living or dead, is unintentional and purely coincidental.
36.Apply brake before shifting.
37.Apply only to affected area.
38.Apply to infested area.
39.Approved for veterans.
40.Article is provided "as is" without any warranties.
41.Articles are ribbed for your pleasure.
42.As seen on TV.
43.Assembled in the United States from U.S. and Japanese components.
44.At participating locations only.
45.Attendant does not have combination to safe.
46.Avoid alcoholic beverages while using this product.
47.Avoid contact with eyes and food.
48.Avoid contact with eyes and skin and avoid inhaling fumes.
50.Avoid contact with skin.
52.Avoid improper microwave use.
53.Avoid magnetic fields.
57.Batteries not included.
58.Battery may explode or leak.
59.Be sure each item is properly endorsed.
60.Because some jurisdictions do not allow the exclusion or limitation of liability for consequential or incidental damages, the above limitations may not apply to you.
61.Beware of Akita dog.
62.Beware of dog.
65.Break glass in case of emergency.
66.Breaking seal constitutes acceptance of this agreement.
67.Breaking this seal voids your warranty.
68.Bridge freezes before highway.
69.Buckle Up, America!
70.By continuing to use this system you indicate your awareness of and consent to these terms and conditions of use.
71.By using this system, the user consents to such interception, monitoring, recording, copying, auditing, inspection, and disclosure at the discretion of authorized site personnel.
73.Call before you dig.
79.Caution: Hot coffee is hot.
80.Caution: May cause drowsiness, nausea, dizziness, or blurred vision.
81.Caveat emptor.
84.Children may be killed.
87.Close cover before striking.
88.Colors may, in time, fade.
89.Computer generated driving conditions.
91.Consult your physician before use.
105.Credit will be extended to those persons born before 1901, as long as they are accompanied by their parents.
106.Current at time of printing.
107.Danger: harmful or fatal if swallowed.
108.Dealer prep extra.
109.Demonstration by professional drivers on a closed course - please do not attempt.
112.Discontinue use if rash develops.
118.Do not attempt.
124.Do not drive car or operate machinery.
127.Do not drive in fields.
130.Do not drive with ball stuck on head.
142.Do not induce vomiting (unless you want to...)
146.Do not leave unattended.
148.Do not look at laser beam with remaining eye
161.Do not remove tag under penalty of federal law.
166.Do not sit under coconut trees.
172.Do not try this at home.
173.Do not turn upside down.
175.Do not use at temperatures under 43 degrees.
182.Do not use near fire, flame, or sparks.
186.Do not use this product if you are currently taking a drug for depression.
190.Do not use while sleeping or unconscious.
196.Dog not included.
197.Doing so will cause injury and death.
198.Don't coast downhill.
201.Don't pet the dog.
202.Don't try this in your living room; these are trained professionals.
203.Don't quote me on anything.
205.Dramatization
212.Eating rocks may lead to broken teeth.
213.Edited for television.
214.Elvis has left the building.
217.Enter at your own risk.
219.Excessive dust may be irritating to shin and eyes.
223.Fasten seat belt while seated.
229.For a good time call 1-800-540-0058.
239.For off-road use only.
240.For outdoor use only.
242.For use by trained personnel only.
249.Handle with care.
250.Hard hat and safety goggles are required.
254.Height restrictions apply.
257.How's my driving?
258.I am a non-attorney spokesperson.
259.If a rash, redness, irritation, or swelling develops, discontinue use.
260.If any defects are discovered, do not attempt to repair them yourself, but return to an authorized service center.
268.If you are not the intended recipient, any disclosure, copying, distribution, or any action taken or omitted to be taken in reliance on it, is prohibited and may be unlawful.
277.In the event of fire, remain calm.
278.Individual results may vary.
279.Information herein not to be used with alcoholic beverages.
283.It is intended solely for the addressee.
285.Just say no.
286.Keep away from fire or flames.
287.Keep away from moisture, rain, snow, gloom of night, and so forth.
296.Keep off the grass.
300.Knives are sharp!
303.Left handed people excluded.
305.Like any driving directions/map you should always do a reality check and make sure the roads still exist.
310.List was current at time of printing.
314.Look before driving.
325.May cause any of the aforementioned effects and/or death.
332.May contain small parts.
333.May irritate eyes.
340.Mr. Smith is a paid endorser.
345.Neither the seller not the manufacture will be liable for any brain damage arising from the use of this product.
346.Never commit arson. Not even once.
348.No alcohol, dogs, or horses.
351.No animals were used during testing.
355.No deposit, no return.
359.No kidding.
363.No money down.
364.No other warranty expressed or implied.
366.No postage necessary if mailed in the United States.
368.No purchase necessary.
369.No returns unless defective.
372.No shirt, no shoes, no service.
373.No shoes, no shirt, no service.
375.No small children.
377.No stopping or standing.
378.No substitutions allowed.
389.Not available in all states.
394.Not intended for highway use.
395.Not intended for use by children or liberals under the age of five.
398.Not liable for damages arising from use or misuse.
403.Not responsible for acts of God.
406.Not responsible for direct, indirect, incidental or consequential damages resulting from any defect, error or failure to perform.
410.Not responsible for typographical errors.
411.Not responsible if you've fallen and can't get up.
412.Not street legal in some states.
413.Not suitable for children aged 36 months or less.
414.Not the Beatles.
420.Now available without a prescription!
429.Only at participating, local dealers
433.Other restrictions may apply.
437.Past performance no guarantee of future results
439.Pavement ends.
440.Pay no attention to the man behind the curtain.
443.Penalty for early withdrawl.
455.Please recycle.
457.Please remain seated until the ride has come to a complete stop.
460.Please return your seats and tray tables to their locked and upright position.
469.Pre-1650 garb required by all participant
481.Proceed with caution.
484.Professional driver on closed track.
491.Read and use at your own risk.
492.Read at your own risk.
493.Read label before using.
496.Rebroadcast is prohibited without the express written consent of Major League Baseball. Record additional transactions on back of previous stub.
499.Reference herein to any specific commercial products, process, or service by trade name, trademark, manufacturer, or otherwise, does not necessarily constitute or imply its endorsement, recommendation, or favoring by the United States Government.
510.Results not typical.
515.Riders of personal watercraft may suffer injury due to the forceful injection of water into body cavities either by falling into the water or while mounting the craft.
516.Road rage is uncool.
526.Seek shelter and cover head.
533.Shipping & handling extra.
534.Should you need legal advice, please consult your lawyer.
535.Shut off engine.
536.Side effects include nausea.
537.Sign here without admitting guilt.
538.Sign waivers with your real name.
539.Simply pour the biscuits into a bowl and allow the cat to eat when it wants.
542.Slightly higher west of the Mississippi.
544.Slippery when wet.
549.So remember, you've been warned!
553.Some equipment shown is optional.
554.Some humor and satire included.
555.Some jurisdictions do not allow exclusion of incidental or consequential damages, so the above exclusion may not apply to you.
568.Subject to approval.
574.Subject to the provisions of the Freedom of Information Act, we cannot disclose to you any information which we may gather and we cannot confirm to you the existence or non-existence of an investigation.
575.Substantial penalty for early withdrawal.
581.Tax, title and license extra.
582.Terms are subject to change without notice.
589.The buyer assumes all risks associated with using this product.
593.The preceding was a paid political announcement.
596.The truth is out there.
597.The user takes full responsibility for everything and anything that could and/or does go wrong resulting in any kind or type of problem, difficulty, embarrassment, loss of money or goods or services or sleep or anything else whatsoever.
599.These documents do not reflect the thoughts or opinions of either myself, my company, my friends, or my rabbit.
610.This is only to be used as an aid in planning.
616.This product not intended for use as a dental drill.
617.This side up.
625.This web site is not intended as legal advice
639.Unleaded fuel only.
645.Use only as directed.
646.Use only in a well-ventilated area.
647.Use only unleaded fuel.
649.Use under adult supervision.
651.User assumes full liabilities.
655.Void where prohibited except where not prohibited.
658.Walk - Don't Run.
659.Warning: All liability waived! Rocketry is an inherently dangerous undertaking. Make your choices and take personal responsibility for the outcome of your experiment! Protect your privilege to fly rockets by not making the headlines or becoming a statistic.
664.Wash, rinse, repeat.
665.Watch for falling rock.
672.Wearing of this garment does not enable you to fly.
673.What you thought was chicken at that Chinese restaurant wasn't.
675.You must be at least this tall to ride.
679.You should have had a V-8.
680.Your actual mileage will vary.
683.Your mileage may vary.
685.Your results may vary.
Disclaimer does not cover misuse, accident, lightning, flood, tornado, tsunami, volcanic eruption, earthquake, hurricanes and other Acts of God, neglect, damage from improper or unauthorized repair, incorrect line voltage, broken antenna or marred cabinet, missing or altered serial numbers, electromagnetic radiation from nuclear blasts, sonic boom vibrations, customer adjustments that are not covered in this joke list, and incidents owing to airplane crash, ship sinking, motor vehicle accidents, dropping the item, falling rocks, leaky roof, broken glass, mud slides, forest fire, or projectile (which can include, but not be limited to, arrows, bullets, shot, BB's, shrapnel, lasers, napalm, torpedoes, or emissions of X-rays, Alpha, Beta and Gamma rays, knives, sticks and stones, et al.)
And, of course...
This supersedes any previous disclaimer
Humor, I love it….
So I stated numerous cold hard facts about the dangers of blurting out answers without any thought or consideration to the variables that pertain to the question that are being asked here. Since my response (the truth) offends you, I do not how to value your wisdom anymore.
Common Sense anit to common. Blurting out an answer without even thinking about variables that are associated to it; is a lack of common sense. I fully understand that under the variables of your personal experiences may have resulted in no issues and only pure successes. I am not you and you are not me. All of your variables are different then all of mine. Please be considerate of the different variables that other people may encounter while performing similar actions that you have had with nothing but pure successes.
Wow did you cut and paste from somewhere or made it up as you went along?i bet that took quite a while LOL. Ok now fellows you both made your point.codyw use common sense/caution until you have experience with the process and always really
If you ever saw National Lampoons Christmas Vacation,you'll understand the line "Where's the Tylenol". LOL
Another thing your gonna want to be aware of that I havent seen anyone mention yet is when your turning on hillsides the tractor may hold the wagon back but the baler may not. One of the guys I help bale hay was turning at the bottom of a hill one time and when the baler started to follow the tractor around the turn, the wagon started to out run the baler sliding it sideways and busting the spindle off of the pickup side. Luckily the wagon jackknifed and stopped itself, and somehow managed to not spill a single bale.
Ya, but a couple of pounds more than the tractor. LOL. I know for sure that some of those bales were over a hundred pounds. The baler itself was heavy.
(quoted from post at 22:47:36 07/23/15) My guess would be way shy of 30,000 pounds.
Maybe you need to double up on your Tylenol and take your talents to the county fair and start guessing the weigths of the locals.
baled hale all over the rolling hills of east tn with a 1650, 520 with thrower and four or five wagons holds approximately 100 to 125 bales; never saw my uncles or dad have any trouble
My neighbor brought his restored 1850 to a 4th of July party one year to show it off and give hayrides. I piled into the wagon with my wife and girls and about 20 other folks for a ride. He let his brother drive it who for some reason took it out of gear on a steep downhill section of the road. He stood on the brakes all the way down that hill probably doing at least 30mph and his face and mine were white as a sheet. Everyone else just thought he was taking them for a thrill ride.
Started out with d 15 Allis stacking bales and moved up to 1650 but as they say I was using a smaller tractor first and had a lot of experience .I always watched who ever was on the baler you always had somebody who thought they could pull the hydro power on to shift down. If I had my dad on the tractor we ran in 4th gear we were picking up after a 7 ft haybine and you stayed busy on the wagon.
One day the oliver broke down and we put the d 15 back on the first bale out went over the top of the wagon
