trans filler location
godtar
New User
I just got this tractor and found out it won't climb mild inclines. I want to check the trans level,,,,,,,I know it is a wet clutch type Do not know model......... where is trans filler location
this is an industrial model oliver parsons with the backhoe removed 6 cylinder diesel runs well....
Thanks,
Doug
Well there were 2 different vendors for those Revers-O-torque units. A serial number and a model number off of the plate on the dash would help. The filter for the reverse-o-torque should be located on the unit itself. The transmission will also have a separate filter.
