Josh in Pa
I am working in a super 88. I am going through the rear adjusting end play and backlash and noticed that the ring gear which is riveted to the differential is loose. No rivets are broken, just loose. Can I tighten them up? Or remove them and bolt it? How would I tighten them, I assume heat them up and peen them? Can I do this in the tractor, or do I need to remove the unit? Is this a sign the tractor did heavy drawbar work? It is a very nice original tractor, but from this and the wear on the drawbar it was probably used a lot at one time.
Josh
Josh
