Fill Plug For Oliver 1800
2underage
I have not used my Oliver 1800 much after I had the head redone and when I started it today I find that I do not have hydraulic pressure. I checked the fluid in the transmission and it is full. Does the hydraulic system have it's own hydraulic reservoir and if so where is the check plug? Somewhere in my piles of stuff I do have a manual for the 1800 but I can not put my hand on it right now. I may have left it at the shop that redid the head but they have not found it yet. Any help will be appreciated.
I Think I have a new and a used book for an 1800C if you need 1. 10.00 on the new 1 + ride. Old 1 would cost you a ride if I can find them.
Thanks but I do have one that I can't fine either. However I will keep you in mind and check back with you in a few days.
Does the PTO work yet? Just in case it is a coincidence that the shaft stripped at the same time! I just had mine out yesterday to work on the shaft for the arms, and it is not going to last much longer.
