1650 no hydraulics or power steering at idle
DLMKA
Not sure what year it is. Loader, 3-point, and power steering don't work at idle. Run the engine up and they work but slow. Hydraulic pump need replaced? How big of a job is it to fix?[/list]
(quoted from post at 11:42:49 07/17/15) Do you have a 3000 PSI pressure gauge? How about a watch with a second hand. You need to do some troubleshooting first!
It's one I'm looking at maybe buying, shooting a lowball $$$ and see if they'll bite. It's local, about 3-4 miles away. I might be able to talk him into letting me do some trouble shooting.
Finally got a chance to get over there with a gauge. At idle no pressure at remotes. At 1/4 throttle (tach not working) the 3-point picked itself up after the tractor hadn't run in 2-3 weeks. I got about 600 psi at 1/4. Half throttle was 1100psi and about 1400 @ full throttle. We're going to pull the relief valve and check that nothing is plugging or stuck. He put new hyd filter on but hyd oil is milky.
