Married2Allis
The 1650 I bought last winter had a leaking ps cylinder and the guy who sold it had run the hydraulic fluid down level low. I pulled the top off and the level was 2-1/2" below the bottom of the dipstick. I don't think the 3 pt lift was used much if at all after the fluid started leaking. Would that have damaged the pump?
Also does the 1650 hydraulic pump pull fluid from the bottom of the reservoir or does it get fresh fluid straight from the filter? - thanks.
