570 head bolt torque
I'll be starting the turbo install soon on my 570 Super with the diesel 339 Hercules.I'd like to check and re-torque the head bolts as it's been 200 hrs since it's over haul.Any ideas of the torque values I should be looking for.I want to cover any weak points that the turbo might bring to the surface.I'm thinking of up to 10 lbs of boost max @ stock rpm's.
Hi Phil:
Thanks for the info.I'll write it in my op manual so's not to forget it.
Also I'm the guy that's been bugging you about the water pump or kit for this tractor.(also a seat back)
Any chance you could help me out.It would be nice to fix my weeping Pump while my tractor is apart for the turbo install.
Thanks.
Tenny Johnson
