oliver crankshaft seal
have a oliver 55 and need to replace the front crankshaft seal.
put in the cork seal several years ago and it always leaked. is there a seal that can be installed between the pulley and the timing cover?
Your welcome John. From what I have been told it is not an easy job on a 550 because you can't get the crank pulley off without sliding the tub ahead a couple inches. Good luck with it, Chuck
