1650 3 point
Finally dug into my 1650 today to find out why the 3 point wouldn't lift. Here are some pictures of the problem. Sure is a lot of work for something so simple. Guess It gives me practice for my 2150 that the 3 point won't go down. I think it's the servo valve on that one.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto24397.jpg"/>
&nbsp;&nbsp; That valve is the a "shock relief valve". &nbsp; Lets say you are going down a road with a load of some type on the 3 pt. and you run over a badger mound and the 3 pt. bounces and generates a hydraulic pressure spike. &nbsp; without this valve you will have a failure somewhere else.
&nbsp;&nbsp; Original elbow was a casting. &nbsp; Later tractors and parts was changed to a precision steel elbow part number 167 772-A. &nbsp; Don't put a cast one back in!
Mr. Star Did you get my e-mail on what dimensions I need to machine the 1750 PTO clutch too to prevent it dragging? Thanks. J.
hi, that very same thing happened to me. I removed the 3pt cyl, from the main casting, then took air and blew the piston out. c drilled out the hole as much as possible then cut threads (cleaned out the hole) with a 1/4 pipe thread tap. purchased a 1/3 npt. elbow and remounted the blow off valve, this was 15 yrs ago and 3pt. still worke like a charm.
