What king of power steering fluid in Oliver super 88
Fatjay
My industrial Oliver 77 has a super 88 motor and I'm assuming super 88 power steering pump. It's low and I don't know what kind of fluid I should add. Any help would be appreciated.
Back in those days the power steering pump was the same no matter if it was a 77 or 88. Type A transmission was the recommended fluid. The filter you need to check is on the inside of the power steering pump. The pump needs to be removed from the generator and then the reservoir removed (2 bolts) from the unit. I will check and see if they are still available. My employer used power steering fluid in his super 88. J.
(quoted from post at 11:47:06 07/06/15) Back in those days the power steering pump was the same no matter if it was a 77 or 88. Type A transmission was the recommended fluid. The filter you need to check is on the inside of the power steering pump. The pump needs to be removed from the generator and then the reservoir removed (2 bolts) from the unit. I will check and see if they are still available. My employer used power steering fluid in his super 88. J.
Thank you, got it. Power steering is working great.
