super 77 clutch
IH400
New User
My super 77 clutch will not disengage. The tractor run great about 3mo ago, but now you have to start it in gear and shut it off to get it to stop.
Is there a service port or do I have to take the cover off to get the clutch lose? If I have to take the cover off, can that be done without taken the tractor apart?
Thanks for any help. Bill W
If you have a field or somewhere you can go. Stick it in a higher gear, push the clutch pedal down and step on the brakes to break the clutch loose. Next time you park it block the pedal down, so it don't rust together again.
