Every once in a while the power steering binds, when I try to turn the wheel it squeels and won't turn in either direction. If I move forward and back a bit, then it turns fine. 90% of the time it's ok, but i'm going to drop the backhoe off, which will put a lot more weight on the front and I need to make sure it's not going to have any issues. The hydraulic reservoir is full, so I was thinking it's in the steering linkage. Any ideas?
Edit: The motor is from a super 88, so the power steering may be off that system. The generator has a shaft strait through it, belt turns the generator, and the shaft on the other side of the generator turns the power steering pump.
