Oliver 80 Carburetor
terrya
I am finishing a rebuild on an early 80 Standard, and have found a bad float in the carburetor. Does anyone have either a carburetor or a float for one? The float is also the same on a 4 cyl 90 or 99, and the carb is a Schebler TTX-19. Thanks, Terry
is the arm on the float still good? They don't make that float anymore. I think this is the correct place Mark's carb. and mag service Rice, MN 320-393-7272 told/showed me they had a float that is almost correct size that they can solder your old arm on to and it would cost bout $40. I've been looking for one for my 99 and got lucky found two parts carbs at swap meet for $5 and one had good float, but kept this guys card in case it didn't work out.
I'm not arguing with OliverNate but the float in an international F/O/W 12 and I think 14 uses an identical float but as OliverNate said you need your original arm. This is available in at least one aftermarket catalog but I don't know if I can mention the name here. My email is open at least in classic if you want the name.
I did this on a on an 80 carb. If you can solder you can do it yourself.
I am going to point out a 99 is supposed to have a 21 carb. I am working on a 99 and it runs on the 19 carb but I cannot tune it to satisfaction. We are waiting on a 21 to show up. A 19 in good shape works good on the 80 row crop I worked on.
RT (my 2 cents)
I cannot access your e-mail, so please send it to me. Yt shows no e-mail listed. I know that the TTX-21 carb had a different throttle shaft for the 90 & 99, and belive that the main jet is a larger size also. Please e-mail me the vendor info at [email protected]. Thanks, Terry
Also, I talked to Treadwell Carburetors in Treadwell, NY. They have new TTX-21 carbs for a 90/99 4 cyl, but no floats. I have purchased floats from them in the past, but they do not have any more in stock, and they are now obselete. Terry.
I've sent you something by the reply button and then noticed you had it in the message
Let me know if you need more but I think you can find it.
RT
