77 hydraulics
Nick167
Can I run a couple hydraulic lines on my 77 from the mech. Pump that's on it? I want use this on a corn picker how much would it cost to run hoses and such?
You will need to add a hydraulic unit or if you put a #4 picker on an Oliver 70 tractor you raised and lowered the picker with linkage from the mechanical lift. That place (used to be Gene's) still open? You should see if he has a unit.
Nick,that picker is way over priced,but if you buy it anyway,I had a lever and linkage around here somewhere to lift one of those with a mechanical lift. I don't know it I can find it or not.
Thanks rrlund I will see if I can find a gathering chain and see how much that would be and maybe try and talk them down some more or make a package deal I'm going to think about I just hate to let the one slip up as I don't know if I'd find another and I think it would be a fun project
