This stuff is off an 1850. I can't remember if it had a hydra power or over/under. I had worked on the tractor for a buddy, rebuild the engine, clutch, was going to reseal the over / under or hydra power, which had leaks all over it. The splines on the shaft were toast, and the parts to repair it were about $1200, and my buddy had spent his budget. I instead replaced it with a straight shaft and bell housing I got from Worthington's for $200. I later owned the tractor, but sold it a couple years back. There was nothing wrong with the drive, buddy said he used it the first couple years he owned it when he actually farmed/plowed with it, but then went to doing hay and never had to use it while pulling hay implements. If someone traveling through Gratiot County MI wanted to pick it up or meet somewhere that would probably work better, as this stuff is pretty heavy. If I have to, I could ship it though. If you want it, please don't take it to sell like the last stuff I gave someone. I hope someone can use it, it has been sitting on the shelf in my shop for the last 10 years, and we only have fleet line Olivers now and none of the "newer" style anymore.
Ross
Ross
