paint color
The PPG# according to Paint codes on the Oliver page is 926052. I used #45641 on my 1800 and it was not right, as it had too blue of a tint to it. I got my PPG# from NAPA in their Crossfire brand. It worked good for me.
Here is the list of paint codes that I've been using:
Here's the latest update on the paint codes...
Below are all of the new PPG paint #'s. PPG is Pittsburgh Paint, and at this time the new numbers will NOT cross over to other paints. They all look really close and I am sure most people will not notice a difference, but when you change brands there may be some slight variation and that applies here. The company sent the MS paint #'s in to the Chemist at PPG and he came up with the matches. The only problem is that until they get the numbers into the national system, (which takes a month or more) the numbers will only be able to be mixed if the person mixing the paint calls our local Arnolds store # for the paint formula. These new numbers will also be available in Canada. These are new numbers that PPG have issued and will be assigned only to the Oliver tractors, so when a customer asks for the number it will say Oliver and the years that is it used, however the red and yellow may not say Oliver and may still indicate that it is used for other vehicles etc. The number that needs to be called for the formula is 319-653-5478, ask for Jason. Hopefully those stores mixing the paint will have the new formula disks in a short period of time. The cost of the paint will be approx $82.00 per gallon, so it is a good idea to get a sample before making a large purchase. And by all means, do NOT use the old Martin Senour numbers they no longer work.
PPG Paint #'s Acrylic or Urethane
Hart Parr 70 Orange Frame Stripe DAR 60080
70 Hart Parr Green 925954
Tractors 1930-1937
Oliver 60, 70, 80 Rowcrop & Standards 925956
Tractors 1938-1946
Fleetlines 66,77,88,99 Green 925955
Tractors 1947 to 1950
Fleetline 1951 & up Supers Green 926052
440,55,660,770,880,950,990,995
Tractors 1951 to 1975
RED 72296
YELLOW 82748
All 50 & 55 series Green 926052
Heather green(Clover White) DAR46536
_________________
Chris Losey
