What motor for a 570 ?
I have a 570 with no motor in it I would like to put a 100+ HP motor in it what can will fit/bolt in ??? I have a 570 super with a turbo charged herc. in it but I can't find another unless someone here has one for sale??? Thanks for any help you can give me
(quoted from post at 08:29:29 06/18/15) 339 Hercules or 298 call phil heisey , 339 should get 100+ easy enough.what are you using it for?
I plan to put it on a notill grain drill I currently pull it with a 100hp Moline I have one 570 turned up and it pulls my 12 row corn planter , who and where is Phil heisey? And thank you !!!
Here is my current 570 I plant corn with at our county fair
I have a D3400 hercules motor I will
sell it is apart but I have all parts
and will need rebuild. I bought for the
block for a gas motor but never built
it. 500.00 804 8six9 670four
(quoted from post at 09:21:49 06/18/15) I have a D3400 hercules motor I will
It's a gas motor ??? I am set up for diesel and LP only ....
(quoted from post at 15:39:48 06/18/15) Looks good! What size tires? What fair was that?
It has 20.8x38 on the back and 11 wide on front I also dual it up in back for planting .... And that is the St. Joe Co. Fair in South Bend In.
D3400 diesel it should over 100 hp stock
it's a newer version of the 339 is a
direct replacement for the 339
I have a '59 570 that I put a GO339 Hercules engine in. The engine came out of a Case combine. By changing the rear mounting plate it bolted right
in. It is rated at 130 HP at 2800 RPM. It won the King of the Hill 6250 lb. award for 2014 with the Oregon Tractor Pullers.
